Help if possible
Old Aug 25, 2019 | 11:09 PM
rawatkins70's Avatar
Default Help if possible
I came across a 350 tHat came out of a 77 c10 currently about to put this set up in a 88 brougham caprice is their any tips or pointers as far as cam fuel injection and headers Vortec heads maybe
Old Aug 28, 2019 | 6:54 AM
oilcanhenry's Avatar
A 1977 350 motor will be a low-compression SMOG carbureted, low-horsepower motor. Best to change the heads out to Vortec heads and install a manifold fitted for the 1988 TBI fuel injection in the Chevy Caprice. You will likely need to put a newer ECM controlled distributor in the build. Better cam is optional, but I'd use a Cloyes timing chain. Ain't nothing better then a Cloyes timing chain set in your vehicle. Rear-wheel drive cars Rock !!!
jimbobjones
Feb 4, 2025 2:11 PM
76 3/4 Cheyenne 350 build
Oct 11, 2018 9:35 PM
kyleguinnip
Feb 6, 2014 1:45 PM
malamute
Feb 28, 2013 7:10 PM
BretNasty
May 5, 2010 8:46 PM
