Help with info on 454
Old May 24, 2019 | 6:17 PM
Scott Green's Avatar
New User
Awaiting E-mail Confirmation
Default Help with info on 454
I have never owned or worked on a bbc. I know almost nothing about them except I’ve always wanted one and finally did. These are the numbers I was able to find.
Block: 3999289
GM10 T
B10 75
Heads: 3931063
I was told it was a 454 and I was able to hear it run & the guy even took me for a ride. It was in his 1974 Pontiac Firebird & he wanted to put the correct manufacture motor in it. It ran well. He kept the carb so I have to buy another one. Before I do I was going to see about maybe a better cam.
Was hoping someone could tell me if this is a good block/heads, what kind of hp this set up might have (ball park). I have done a little bit of reading & looks like ok heads but says they were used in 427’s from 69-70. I do know the heads have roller rockers.
I’ll be putting it in my 1954 Chevy Truck & was hoping to get about 500 hp. Any input is appreciated.
Old May 25, 2019 | 2:08 AM
oilcanhenry's Avatar
Block: 3999289
GM10 T
B10 75
Heads: 3931063
Most mid-1970's engines were lower compression engines for smog control..The 454 had various power levels. as low as 270 HP.. with the correct cam and a good carb (Holley or Carter/ Edlebrock in the 650 to 750 range should help, Don't touch an R-C Quadrajet) Hope you have a very solid rear axle in your 1954 Chevy pickup.too.
Old May 25, 2019 | 10:42 PM
Irish_alley's Avatar
I'm here for the party
i would call or get a hold of a cam company (like comp cams) and tell them what your working on and they should be able to tell you what setup (even carb cfm) to go with. i would prob get a holley over edlebrock but thats just me
