Help slave cylinder braided hose leak
Just pulled tranny replaced slave cylinder MANUAL 5 SPEED CLUTCH.didnt check under the truck and the plastic clips that hold the braided cable from master cylinder to slave connection. Was hanging the plastic clip hit the exhaust and melted into the line so now brand new slave line is leaking out brake fluid everywhere.**** PLEASE I NEED A FIX AND DONT WANT TO PULL OUT TRANNY AGAIN. ANYONE SUGGESTIONS
to used something other then screw-type hose clamps to secure the line to the steel braided hose portions, like SS single-ear pinch-type hose clamps.
I dont really know what kind of pressure it takes to release the clutch slave hydraulic throw-out bearing, but my guess is that its much less then the pressures of a hydraulic braking system.
The worst thing that could happen is the repair doesn't work for long, and you have brake fluid spraying all over the place, which you'll need to wash off before it destroys your vehicles paint job. If out and about if it fails, you can always have it towed, or you can learn to shift a transmission without a clutch and baby it home, or to a shop.
thanks for the replies
