Horn replacement
Horn replacement
I would like to replace the stock horn with a pair of Stebel Electric Horns. Can I use the stock wiring and steering wheel button. Do I need to increase the size of fuse, do I need to run the hot wire to the battery. Anything else I need to know.
Compare the amp rating for the horn you want to the fuse size of your O.E.M.
horn.
If the new one is equal or less amps then the old horn, then you can definitely utilize the current wiring and steering wheel button.
Worse case is that the new one will have to utilize a $4 relay to power the horn from the battery. Triggered via the old wiring.
horn.
VegasF6
February 5th, 2011 10:05 AM
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
December 26th, 2007 9:23 PM
zulu
March 28th, 2007 4:58 AM
