How to get belt driven air compressor
Old Sep 21, 2013 | 8:21 PM
John McGarva's Avatar
Default How to get belt driven air compressor
Hey all. Im not sure if I'm in the correct forum or not, so feel free to move it. I thought it would be okay here, since im looking for something for a motor thats in more than just a silverado...
Anyway, I have train horns on my truck. I have a 2011 1500 silverado. I'm running a 5 gal tank, but looking for go bigger. I have an air compressor right now that's wired to the ignition and runs when the truck is running. I use the horns quiet a bit, and it gets annoying listening to the sound of the compressor rattling the frame of the truck...
I was wondering, if it was possible to hook up an air compressor to the belt drive of my truck. I work for the fire dept, and I see that fire trucks have these types of compressors...
The thing is, I need the compressor to stop at 150 psi.. I do have a relief valve rated for 150 psi. But right now, the compressor I have, has a brain, and shuts off at 150 psi and turns back on when it gets lower than 110psi. With these belt driven air compressor, is there a way for it to shut off? Or is it always running, and always opens the relief valve every-time it gets full? I'm not sure exactly how these work, and if its even possible to mount one on my engine. I have the 5.3L v8 fuel economy engine ( if that helps any)
Thanks in advance.
Old Sep 22, 2013 | 11:22 AM
SWHouston's Avatar
Belt drives work almost the same way as the Motor Driven.
Just imagine how your A/C compressor works (the Clutch in the front of it) and your pressure limit switch engages/disengages it just like the A/C.
Any Pressure Relief Valveing you have, should be related to the Tank Capacity (stamped on the side of the tank), and not involved with the Compressor.
IF your present Pressure Regulator is separate from your drive motor, all you need to do is change Compressor.
When/if you change this out, remember you're going to have to have a flexible line between the compressor and the rest of the system.
(don't be cinchy on the length)
pancho88
Jul 21, 2012 8:56 PM
Steeltown
Jun 22, 2011 8:24 PM
redtress
Oct 11, 2010 11:20 PM
Ricardomkz
Jul 17, 2010 1:51 PM
DCSCO
Astro
10
Apr 5, 2010 9:57 AM
