How to program keyless remote
Old Dec 1, 2007 | 6:17 PM
Stacey's Avatar
Default How to program keyless remote
Hi all! I'm new here and couldn't find any info on programing a remote for a 2002 Chevy Suburban....I have one remote that quit working, I replaced the battery but it still doesn't work. Any ideas?? Any help would be greatly appreciated!
Stacey
Old Dec 2, 2007 | 10:02 PM
John86's Avatar
Default RE: How to program keyless remote
Transmitter Programming Procedure (Method 1 - No Tools Required)
[ol]Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation. [/ol]
Old Dec 2, 2007 | 10:22 PM
Stacey's Avatar
Thank you!!!!!!!!
Old Jun 15, 2009 | 9:49 PM
irishelysia's Avatar
does anyone know if this will work for a 2004 malibu?
Old Jul 7, 2009 | 6:58 PM
sgad's Avatar
Default how to reprogram a keyless entry on a 2002 chevy blazer
hi
Could anyone tell me how to reprogram a key less entry on a 2002 chevy blazer LE
Thankyou
Old Aug 18, 2009 | 5:56 PM
smokin_thoughts's Avatar
is the keyless remote from a 2008 cobalt compatible with a 2000 cavalier?
in general are there any compatible remotes for GM vehicles?
Old Aug 28, 2009 | 7:17 PM
wattup1jcm's Avatar
Stacey did theinfo on the keyless remote work for you.
Old Aug 28, 2009 | 7:18 PM
wattup1jcm's Avatar
Will this work for my 1999 Suburban
Old Oct 6, 2009 | 2:17 AM
Suburban_8,1's Avatar
Thumbs up 2003 Suburban - works well
Thanks a million.
Just did it on my 03 Suburban 8,1......works perfectly !!
Old Oct 28, 2009 | 2:27 PM
nfoucht's Avatar
will this work on a Chevy Colorado 2007?
