HVAC fuse keeps blowing
Old Aug 15, 2008 | 3:26 PM
stretchslocum's Avatar
Default HVAC fuse keeps blowing
I have a 99 Monte Carlo LS. The HVAC 15 amp fuse keeps blowing. I thought itmight be my blower motor of the resistor but it only happenswhen my automatic headlights come on in the evening. Obviously the automatic headlights are wired to the fuse,but how do I go about correcting the problem.
Old Aug 19, 2008 | 8:05 PM
jkgray80's Avatar
Default RE: HVAC fuse keeps blowing
You could still have a blower motor or resistor issue. Blower motor could be pulling to many amps ,but not enough to pop fuse until headlamp load is added. You're gonna have to isolate it to headlamps or blower/resistor.
Old Aug 20, 2008 | 4:12 PM
shawnvw's Avatar
Banned
Try removing the DRL module. Its under thedrivers side of the dash. The module may be shorting internally causing your fuse to blow. With the module removed, the right high beam will not work, but at least you can narrow the problem down a little further
Old Aug 22, 2008 | 10:28 PM
khooper's Avatar
bad blower motor itself would blow the blower motor fuse and also have toasted that resistor. either the motor itself is bad, or theres debris in the box which has jammed the blower motor.
____________________________
Autopartswarehouse Addict.
Drive Safely and Move Freely.
hunteredpete
Jan 30, 2016 8:25 PM
les4metal
Apr 20, 2010 2:48 PM
clwill65
Astro
May 15, 2008 4:53 PM
Mercpuman
Jul 11, 2007 12:03 AM
kathedi
Jan 2, 2007 9:14 PM
