Ignition is stuck in lock? Drilled it out and nothing
Old Aug 23, 2025 | 10:38 PM
Chrismustangcavguy's Avatar
Default Ignition is stuck in lock? Drilled it out and nothing
Just bought an 03 cavalier for a daily. How do I remove the ignition. It's stuck in the lock position. I even drilled out the lock cylinder and it wont rotate. The original key was having issues turning and wouldn't go past lock which is why I want to drill out and replace. Am I missing a trick? Why wont it rotate without the cylinder? Tried some screwdrivers and it wont turn past on.
Old Aug 24, 2025 | 10:04 PM
Robby17's Avatar
The steering wheel is locked. You need to remove the entire ignition switch assembly, not just the cylinder. The lock mechanism is part of the housing. You'll have to drill out the security bolts holding the switch to the column to remove it.
scoutmstr
Jan 13, 2025 12:49 PM
Ryan0811
Sep 24, 2021 11:32 AM
frosome
Dec 12, 2014 7:15 PM
Arborist1212
Jan 12, 2013 8:39 AM
Rivernut
Dec 20, 2007 10:54 AM
