key fob programming instructions
Can anyone get me the programming instructions for late model gm/l format key fob. Specifics= 2005 Chevy Uplander. I bought an additional fob. Some of these ya-hoos online will sell me the instructions for $15 or I have to take it to the dealer and have them program it when it's something I could totally do on my own if I had the instructions. Thanks in advance for any guidence on this.
According to this sitehttp://www.programyourremote.com/
Uplanders cannot be programed yourself. Not sure i beleive that. Try this
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver's door panel-continue to hold down until instructed to release.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
11. Repeatstep 10NOWfor each additional transmitter (including any existing transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
This site doesn't have 07s so see below...
If you have an 07 with DIC thisMAY work
Relearn Remote Key[align=left]This display allows you to match Remote Keyless[/align][align=left]Entry (RKE) transmitters to your vehicle. To[/align][align=left]match an RKE transmitter to your vehicle, do the[/align][align=left]following:[/align][align=left]1. Press the vehicle information button until[/align][align=left]PRESS V TO RELEARN REMOTE KEY[/align][align=left]displays.[/align][align=left]2. Press the set/reset button until REMOTE KEY[/align][align=left]LEARNING ACTIVE is displayed.[/align][align=left]3. Press and hold the lock and unlock buttons[/align][align=left]on the first transmitter at the same time for[/align][align=left]approximately 15 seconds.[/align][align=left]A chime will sound indicating that the[/align][align=left]transmitter is matched.[/align][align=left]4. To match additional transmitters at this time,[/align][align=left]repeat Step 3.[/align][align=left]Each vehicle can have a maximum of eight[/align][align=left]transmitters matched to it.[/align][align=left]5. To exit the programming mode, you must[/align][align=left]cycle the key to LOCK.[/align]
ORIGINAL: klswanky
I would also like the instruction if you please. GM/L 2007 Uplander
Has anyone figured out how to program a 2007 Tahoe/Suburban remote / fob??? If so, please provide instructions. I lost my remote and got a new one. Need programming instructions, is it even possible to do without going to the dealer. Thanks!
kcarberry
Jan 24, 2014 5:37 PM
onegodapostolic
Sep 29, 2008 9:53 PM
2000, 2007, avalanche, carlo, chevy, corvette, fob, instructions, key, monte, program, programing, programming, remote, reprogramming, tahoe
