Key will not turn - 2005 express 3500 A/T
Old Mar 22, 2010 | 6:44 PM
KenC's Avatar
Default Key will not turn - 2005 express 3500 A/T
Went out to start the rig but the key will not turn. I tried turning the steering wheel, disconnected the battery, checked the fuses, and even took the steering wheel collar off and released the shift lock and tried turning the key in Neutral. I WD40'd the key hole and tried both sides of the three keys we have. None of this has worked.
I am at the point of removing the key cylinder but I cannot remove it with out putting the key in ACC. I read somewhere that I can drill through the key cylinder housing but I need more detailed instructions of how to do this. Also what will I need to do aside from replacing the key cylinder? Otherwise, any other ideas will help.
Thanks in advanced.
PS. Im a newbie, any advice will be great.
Old Mar 22, 2010 | 8:08 PM
gotstylez's Avatar
im my truck if your wheel is turned all the way.. you have to put some force into turnign the wheel the same same the wheels are turned to get it turn..only happens if the wheels are turned tho.. when it happens i cant turn it either way
Old Mar 23, 2010 | 10:39 AM
KenC's Avatar
I tried turning the wheels both directions and tried the key with no luck. The wheels are almost straight and not leaning on a curb either. Thanks anyhow.
Old Mar 23, 2010 | 2:44 PM
therewolf's Avatar
Are you parked facing upward in a sloped driveway or a hill?
If so, the weight of the vehicle may be locking up the steering column on you. Try getting a little help and pushing the Van up just far enough that the key will turn to start the vehicle, then maybe a quick upward push to get it into gear...
Randall Kogelman
15
Apr 15, 2026 7:25 PM
goyakpacking
May 9, 2015 7:51 PM
G T Igofast
Sep 3, 2013 3:46 PM
kazamterk
Jul 25, 2012 11:25 AM
Mr. Vann
Nov 25, 2009 7:24 PM
