knock sensor and temp sensor
Old Mar 10, 2008 | 2:32 PM
jffgin's Avatar
Default knock sensor and temp sensor
hey, question is. I got a 1995 S-10 ZR2 4.3 W, Where is the knock sensor located? The reason why I ask is, when I start my truck after it has cold down for 7 + hours I have a knock i let it idle for a few minutes and it goes away, I figure if it was something real serious internal I would have a knock constantly. But when i drive I hear a very soft constant ticking. I do have a coolant leak somewhere and some posted I might need a new intake manifold gasket.
Second question I believe I found the problem for my temperature gauge not working. I think it is the temp. sensor i found an unpluged wire by the egr and the wire from the sensor I believe but not sure coming from top behind water pump that has been cut. Maybe I forgot to reconnect one time when cleaning the egr. what is the easiest way on removing the temp sensor and does the temp sensor come with wires?
Rmbb
Mar 25, 2014 3:37 AM
skategranger
Feb 18, 2013 2:38 PM
montana suburban
May 11, 2010 5:19 PM
Mauler
Mar 2, 2009 6:40 PM
