Larger Distributor Base
Old Aug 7, 2017 | 10:58 AM
gary joshway's Avatar
Default Larger Distributor Base
I have a 56 Chevy Bel Air and I've upgraded from a stock distributor points to an HEI Distributor; however, the HEI Distributor is larger in diameter at the base and when I try seating it flush; it won't go all the way down because it's hitting up against aluminum Eldebrock intake manifold? Thoughts on how to rectify dilemma?
Regards,
Josh
Old Aug 7, 2017 | 6:21 PM
Get a distributor designed for that intake.
Old Aug 7, 2017 | 7:26 PM
kevinkpk's Avatar
If you're going to run a high rise manifold, you need to have a distributor to fit that,
