Leaking oil from intake manifold
Old Oct 7, 2011 | 3:32 PM
tssiTanker's Avatar
Default Leaking oil from intake manifold
It has now been 1 year and 3 months since I replaced the seal on my intake manifold, because it was leaking coolant. About 5 months ago it started leaking oil badly (1 and a 1/2 to 1 quart a week). At first I thought it was the oil pressure sensor, but it isn't because I replaced it 3 times. I thought it might have been my rear main seal, but then but both transmission places I took it to said it wasn't. The first place told me they didn't know where it was coming from, but it's not the rear main seal, and the other place hosed down the entire underneath of the car, and the started it on the lift and they said it was coming from the intake manifold, and that i might also want to put a distributor gasket on (which i did, and it still leaked).
When I replaced the manifold 1 year and 3 months I torqued the bolts to 30 ft lbs like the book said, and put RTV on the front and rear of the engine, and on both side of the gaskets.
Why is it leaking now? Would re-torquing them stop it or slow the leak significantly?
92 Buick Roadmaster 5.7 TBI Sbc
Old Oct 20, 2011 | 7:16 AM
Alem's Avatar
Has your oil started to get greyish and slimey? If that is the case, then your leak has compromised your lubrication system and could cause some internal damage. Do you know how long your engine has been leaking coolant? Two weeks likely won't harm you engine severely (or at all), but I would keep my driving to a minimum just to be safe. They will (or should) change your oil when they do your manifold/water pump work.
EV
HeavyChevyTom
Jul 25, 2012 9:23 AM
knucklebust
Jun 12, 2010 7:21 PM
isaacsnr07
Jan 12, 2010 9:36 PM
rodeoson
Dec 7, 2006 12:39 PM
