left turn signal not working on outside of the truck
Old Oct 5, 2014 | 8:01 AM
carpetogie's Avatar
Default left turn signal not working on outside of the truck
My left turn signal indicator is flashing normally on the dash, but no lights are flashing on the outside of the truck. When I turn on the hazards, same thing (right side works not the left). Several weeks prior I had noticed that the left side rear light was not flashing when a trailer was connected. (May not be related). I pulled the flasher relay and re-seated it with no change. Any ideas, I'm stumped.
Brad
Old Oct 5, 2014 | 7:05 PM
slugranch's Avatar
Not very probable that both front and rear bulbs are bad, but it's something to check. Also check where tow connector was wired to left tail light. Might have broken a wire,,,,,Use a test light and see if the wires feeding the front and rear lights have 12 volts entering the fixture when the TS or hazards are activated.
Yogi
Dec 12, 2021 6:25 PM
RomanGuzi
Oct 2, 2011 11:40 AM
derrik38
Jun 13, 2007 9:09 AM
derrik38
Jun 4, 2007 10:02 PM
gamato
Jan 21, 2007 1:06 AM
