lost my key
Old Sep 20, 2009 | 11:42 AM
nauticstar87's Avatar
Default lost my key
lost my keys to my receiver hitch. I have the locking pin from Reese. Any ideas other than a torch?
Old Sep 20, 2009 | 2:02 PM
Mike Sigmond's Avatar
ROTM Coordinator
Try calling the manufacturer and give them a serial #, maybe they can send you a new key. I have drilled out key barrels before and had success, I am not sure if that will work on this application, but Id try that before torching it.
Old Sep 21, 2009 | 10:03 AM
therewolf's Avatar
I'm a bit of a ditz when it comes to keys and paperwork and stuff. What I try to do is re-create the situation when I set the key(s) down. I ask myself"What's a good place to store a key I'll need later, but won't be using for a while?". Then I go look in those locations.
If that fails, there's always a grinder. If it'll work on your lock, it'll stress things under your truck less than a gas-wrench.
Old Sep 21, 2009 | 9:14 PM
jeffs_62's Avatar
Local lock-smith
Old Sep 23, 2009 | 9:23 AM
LocalEnough's Avatar
Ive always steered clear of torches, all that extra heat isnt good on metal. I have used many Ti drill bits and locks, its about 90% cheaper than a lock smith.
Calling the manufacture sounds like a good start tho, might save a drill bit.
LE
Old Sep 23, 2009 | 9:33 AM
had to switch hitches yesterday just took a torch to the lock. not the best idea but had to get it done. When I buy a new lock I'll put the keys in a better place. thanks for the advice though.
kcarberry
Jan 24, 2014 5:37 PM
G T Igofast
Sep 3, 2013 3:46 PM
chevykicksbut
Oct 23, 2010 12:32 AM
dave54000@hotmail.com
Jun 20, 2010 1:06 AM
TahoeRob
Feb 9, 2005 11:31 AM
