Lost pushrod
Lost pushrod
I have a 350 small block used in a dirt track car. I think valves floated and ended up breaking a pushrod. I found 1/3 of it in the oil pan, but can't find the rest. I've looked in lifter valley, timing chain cover, and oil pan. Any ideas where it would be?
Location: Currently the Candian Gander is wintering over in New York.
1 Post
Justin, since you have the valve covers off, you should be able to locate which rocker arm is sloppy floppy and missing push-rod contact. Remove the hold-down nut and rocker and use a strong flashlight to look down the push-rod tunnel. My suspicion is that the missing 2/3rd bounced around on the lifter and is resting somewhere inside of the tunnel, out of sight from the intake galley..
If that is the case, you may have to fish a magnet down into the hole to pull it out. You may only have to replace the broken push-rod. The valves might be fine.
1 Post
Sorry, I figured that anyone smart enough to run and maintain a circle-track racecar who had already diagnosed a potential valve float issue, removed the oil pan, intake manifold, and timing chain cover was smart enough to pull the valve covers to look for a MIA part before he asked his question in here. My mistake.
1 Post
Can you post a picture of the part you were able to recover? Also, it occurred to me that whatever oil drain hole the broken piece you recovered fell into the pan from might be holding the second piece in place.
