Low vacuum 383 Stroker
Old Aug 22, 2020 | 10:35 AM
Devon32's Avatar
Default Low vacuum 383 Stroker
Good afternoon,
I recently got a project car. I was told it is a Chevy 350 crate with the 383 Stroker kit. It has been very sluggish when I floor it. I checked the vacuum and it’s very low, bouncing between 8-10 inches. I have tried all three ports on the edelbrock 1406 carb and same vacuum. However, when revved to about 2k rpm, it goes to a steady 20ish. I sprayed carb cleaner to try and find a leak but nothing. I also tried adjusting the timing by finding the highest vacuum but that didn’t change anything at idle. What should I check?
Thanks!
Old Aug 22, 2020 | 4:41 PM
Little Bear's Avatar
Two things come to mind, cam with a lot of overlap, or a improperly installed cam.
Old Aug 22, 2020 | 4:48 PM
kevinkpk's Avatar
Originally Posted by Devon32
Good afternoon,
Thanks!
One heck of a vacuum leak, with what you post, you should be able to hear it. I'd suggest looking at the carb base gasket.
Old Aug 28, 2020 | 6:01 AM
Mraksina's Avatar
For myself, I've long since discovered a service with a fair pricing. I've asked my buddies to compose papers for me for years after they suggested nursing essay aid. Writing a term paper is truly a difficult chore, especially the beginning is difficult for me, therefore I utilize the services nurse writing of helpers. I trust them, and as a student it helps me a lot to save time.
mattswan267
Jul 26, 2015 10:07 AM
justin211
Feb 11, 2015 4:44 AM
robertjhaley
Oct 15, 2014 8:18 PM
d. joshua
Mar 25, 2010 7:45 PM
