Lubricants for door locks, hinges, latches, etc.
Old Jan 29, 2019 | 11:07 PM
Inari's Avatar
Question Lubricants for door locks, hinges, latches, etc.
What lubricants are best for things like door locks, sliding door rollers, latches and electrical connections? I've heard that WD40 gums up the works and shouldn't be used. Is that true? I also have Jig-A-Loo and Fluid Film lying around. Are any of them any good for Chevy vehicles, or should I buy something else?
Thanks,
Inari
Old Jan 29, 2019 | 11:36 PM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
I am sure many have ideas.
What I have found that works for me is a graphite-based lubricant with solvent based carrier that evaporates, and leaves the graphite in place, .like this:
https://hardwareonlinestore.com/inde...iABEgIXSfD_BwE
Home Depot is one of the few places that I have been able to find it. Wear gloves. The stuff stains anything it comes in contact with.
I don't know about use on electrical connections. The stuff is as flammable as hair spray. Graphite pencils weren't used in the NASA program because graphite could / would have contributed to a fire risk.
Old Jan 30, 2019 | 3:41 AM
astroglide
Old Jan 30, 2019 | 2:30 PM
Just kidding. Horses for courses.
Use whatever oil you have for the hinges. (3-in-1 etc.) It does not matter! I've used cooking oil from the kitchen.
However, WD40 is not good for hinges. Too thin. It's ok for locks.
They make corrosion resistant silicone sealants specifically for electrical connections (also called "dielectric grease").
Old Jan 30, 2019 | 6:10 PM
oilcanhenry's Avatar
Thanks,
Inari
Lithium grease works well on dooor latch and door hinges. WD-40 is ok to use in locks at very cold temps, but there are are many others.
