Main instrument cluster lights and gauges not working
Old May 14, 2025 | 8:51 PM
onoahimahi's Avatar
Default Main instrument cluster lights and gauges not working
Hi - I just took my 2014 2SS Camaro Convert out of winter hibernation and main instrument cluster lights and gauges including the gas gauge are not working. I swapped fuse 4 with 5 with no change. The only cluster light that works is the check-engine light which comes on when I turn the key to on and goes off when I start the car. The car is not throwing any fault codes and runs fine. The backstory is that the car has been in storage for 5 months and when I went to start it the battery was dead. I tried jumping it with a booster with no luck. I put a battery charger on it for 6 hours and then it started right up. Then I noticed the main cluster lights and gauges are not working. I'm telling the whole story in case it is relevant somehow. I did a electronics/computer reset by disconnecting the negative battery cable in the trunk for 30 minutes and nothing changed.
Any suggestions would be greatly appreciated.
Thanks,
-Scott
usarmyharley
Nov 20, 2024 12:09 PM
tekniq
34
Jul 4, 2022 1:26 PM
TM8
Jan 3, 2018 2:34 PM
mandy522
Oct 7, 2016 8:02 AM
slash11
Sep 19, 2015 5:34 PM
