Methanol fuel use in flex fuel engine
Old Dec 8, 2017 | 9:15 PM
Yogi's Avatar
Default Methanol fuel use in flex fuel engine
I would hope that this question is of the general tech type. I have a flex/fuel system in my vehicle. And, lately, my gas gauge has been not reading as full when I get a fill up at the gas station. I have rarely used ethanol/Corn fuel to run my engine. But, I am wondering if using the E-85 would cause a saturation problem with the float in my gas tank. Anyone else on here had such an experience or know if E-85 will cause the fuel gauge to read erratically from time to time. Or, sink a bit just enough to give a false reading when the tank is actually full?
Last edited by Yogi; Dec 8, 2017 at 9:16 PM. Reason: Heading won't edit, but I meant it to tread Ethanol E-85
Old Dec 9, 2017 | 10:12 AM
doubt it. if you remove the sending unit...there is usually black gunk on the potentiometer of the sending unit. happens to flex fuel and non flex fuel vehicles.
