Misfire Silverado need help
So I have a 2008 Silverado 1500. I had a misfire in cylinder 8 reporting. At that time I replaced the plugs and wires. Still was having the issue so I took the following steps in order- checked the fuel injectors these were fine, did a compression test again fine, checked the rocker arms all fine then finally did a fuel/carb clean on the truck. After that the truck was fine again in fact even gained more power. After a month of driving it maybe putting 500 miles on it the truck started misfiring again. I am so lost to even figure out where to continue. If anyone has any ideas It truly will be appropriated.
