Misfire Silverado need help
Old Dec 17, 2019 | 7:35 PM
Fighter911's Avatar
Default Misfire Silverado need help
So I have a 2008 Silverado 1500. I had a misfire in cylinder 8 reporting. At that time I replaced the plugs and wires. Still was having the issue so I took the following steps in order- checked the fuel injectors these were fine, did a compression test again fine, checked the rocker arms all fine then finally did a fuel/carb clean on the truck. After that the truck was fine again in fact even gained more power. After a month of driving it maybe putting 500 miles on it the truck started misfiring again. I am so lost to even figure out where to continue. If anyone has any ideas It truly will be appropriated.
Old Dec 18, 2019 | 5:20 AM
oilcanhenry's Avatar
Likely dirty fuel injectors. # 8 i just the worse for now. Thats why the motor ran good after using gad additive.
Old Dec 18, 2019 | 3:40 PM
Fighter911's Avatar
We switch the fuel injector with cylinder 3 and 8 was still miss firing before the clean was done.
Old Dec 18, 2019 | 3:59 PM
kevinkpk's Avatar
Is it still just #8? What does the spark plug look like?
Old Dec 18, 2019 | 4:50 PM
Fighter911's Avatar
Still 8 the plug looks good but cylinder 7 plugs was really bad when I changed it to the point it looked like it was built up carbon. But 8 was and is good.
Old Dec 18, 2019 | 5:14 PM
kevinkpk's Avatar
Well, I'd suggest valve seals
PMC45
Dec 7, 2017 9:25 AM
tng196664
Mar 9, 2015 8:09 AM
SlickRick19
Apr 30, 2014 8:10 PM
tfulcher
Apr 27, 2014 12:08 PM
temills
Dec 16, 2006 6:35 AM
