motor mounts
Old Apr 22, 2019 | 9:39 AM
kep442's Avatar
Unhappy motor mounts
I removed a chevy 350 1980 4wd pickup motor. I replaced that 350 with a 350 from a 1979 rwd rv. I swapped the motor mounts from pulled 350 to rv motor rightside does not come down far enough to replace center pin. What did I do wrong???
Old Apr 22, 2019 | 3:35 PM
kevinkpk's Avatar
Might just be hung up on the bushing. Have you tried a bar between the top, and bottom of the mount, wiggle it see if it falls into place. Make sure you keep a jack under it, but not tight against it.
Old Apr 23, 2019 | 9:21 PM
Irish_alley's Avatar
I'm here for the party
i know when i swapped motors in my 79 i had to fight and fight to get the mounts to line up. but it eventually went
