Motor Swap Trans Question
Old Jun 9, 2010 | 1:11 PM
Viggen's Avatar
Default Motor Swap Trans Question
Hi,
Ive got a Land Rover that I am looking to transplant a 4.8 V8 into. My dad has a chipped 4.8 and its been a great motor and its power numbers are more than enough to move the monster smartly but not endanger the stock transmission. My question revolves around the stock computer. I realize that these are all drive by wire throttles so I will need to transplant the gas pedal assembly to make it work but before I shell out the big bucks on a stand alone kit, I would rather use the stock ecu since itll be on the motor when I receive it. So, here is my question: Is there going to be a problem with the lack of communication to a GM transmission? The trans in the Disco is mechanical and self contained using no computer at all. I am hoping that I will not need to also transplant the 4L80E to make the stock computer work. If thats the case, Ill find a stand alone that will work well for the motor.
Thanks and hope you can help!
Old Jun 9, 2010 | 8:44 PM
MDTAHOE's Avatar
Professional Mechanic
I doubt anyone has done this before so I think you may not get many responses.
Old Jun 10, 2010 | 9:09 PM
72c10gunn's Avatar
I think you will have trouble with that, the computer uses vehicle speed sensors (vss) that are on the tranny, but there may be a way around it. good luck
Burban_Vince
Jul 21, 2014 7:36 PM
leroy2008
Dec 21, 2012 7:14 PM
Rick Austin
Dec 4, 2011 6:25 PM
