Need Help BBC Cam
Old Jan 21, 2021 | 10:41 AM
Todd_tn's Avatar
Default Need Help BBC Cam
What I know: BBC 402, Oval port 454 heads, CompCam 1.7 Roller Rockers.
- Choppy idle
- Seems to run best at 14-16 degrees initial timing
- 6.5 inches of vacuum at idle
No cam specs came with the car when I bought it (1970 Nova). Lots of quality parts on this car.
Whoever built it didn't go cheap.
I'm guessing it's a Comp Cam b/c of the rockers. Called Comp Cams and they say the part number
is on the back of the camshaft, so I can't simply remove the timing chain and see the number.
I'm about to convert it from a 750 Holley to Edelbrock EFI and the setup for the EFI asks for a cam
duration range. Mild: 210 - 230 degrees or Race: 230 - Greater
Questions ? Comments ?
What do ya'll think ?
Old Jan 28, 2021 | 8:17 AM
Littlefield's Avatar
- Choppy idle
If you really need the info you can use a degree wheel and indicator to measure the cam events and lift.
dus10
Jan 7, 2015 9:08 PM
jonathan_l_b
Dec 25, 2013 6:16 AM
eturner
May 30, 2012 1:06 AM
roach502
Aug 25, 2006 3:41 AM
