Need help with UCA question ASAP
Old Jun 20, 2021 | 9:32 AM
D. Legg's Avatar
Default Need help with UCA question ASAP
I ordered the protune UCAs before reading how big of a mistake that was and I’m needing to replace the bushings OEM are to small do I need to burn the rubber out of the protune bushings and use the outside sleeve to make the OEM bushings fit?
Old Jun 20, 2021 | 9:58 AM
D. Legg's Avatar
The control arm is moving left and right on the bushing because there is no lip I’ve never seen this style bushing before it was great at first then boom junk
Old Jun 21, 2021 | 9:25 AM
what ru driving?
Old Jun 21, 2021 | 11:07 AM
D. Legg's Avatar
Originally Posted by tech2
what ru driving?
02 1500hd
Old Jun 21, 2021 | 1:42 PM
any heat for removal or install will wreck the bushing. rock auto has the correct part.
Old Jun 21, 2021 | 2:46 PM
kevinkpk's Avatar
I wouldn't do anything other than take those back, and replace with the proper part. Control arm bushings a re a royal pain, but not as bad as ball joints. You are also looking at a safety issue with modifying them.
gixxerscott
May 20, 2021 10:15 AM
agarcia323
Jun 3, 2020 9:37 PM
Colleen Reyna
Jan 5, 2020 1:01 PM
myjunk
May 31, 2015 7:37 PM
