need info on engine
Old Feb 3, 2010 | 7:36 PM
black bart's Avatar
Default need info on engine
can anyone tell me if the 1.8 in a 2001 prizm has solid lifters or hydrolic? mine has 182,000 miles and has a tap at times. just bought this car and have no info on it. thanks.
Old Feb 5, 2010 | 4:57 PM
black bart's Avatar
ticking from valve train at times, there is a sticker under the hood that shows valve adj. gap, leads me to believe they are solid lifters, but I'm not sure. doesn"t seem to bother how it runs, doesn"t seem to use oil, but only had it a few days.
Old Feb 5, 2010 | 7:25 PM
black bart's Avatar
I'm thinking you guys don"t want to talk to me because a prizm is a toyota GM half breed. I bought it to drive to work because I have a 80 mi. round trip and my s10 wasn"t very good on gas, and I got it real cheap, has 183k on it, but seems to run pretty good.
Old Feb 12, 2010 | 7:16 AM
MDTAHOE's Avatar
Professional Mechanic
The lifters are adjustable. But if it were a adjustment problem it would tap all the time.
Old Feb 13, 2010 | 3:46 PM
black bart's Avatar
ok, thanks, I changed the oil and the lifter noise is only present for about a min. when it"s started cold, then it stops, but it is using about a quart in a thousand miles, any suggestions?
Old Feb 13, 2010 | 4:05 PM
nauticstar87's Avatar
How many miles you ahve on it?
Old Feb 13, 2010 | 9:17 PM
black bart's Avatar
Default re
183000
Old Feb 13, 2010 | 9:28 PM
that could be why its using a qt every 1,000miles. And 1gary did say in his first post that they are known for using oil. Its annoying but I've seen vehicles use a lot more and run fine. I'd let it be. Or rebuild.
Old Feb 14, 2010 | 5:39 AM
black bart's Avatar
I believe you are right, alot of miles, I put some STP in it, seems to have helped a little. a friend of mine who is a mechanic told me to put in a qt. of trans fluid in it and run it 100 miles then change the oil again, says it will clean it out, guess it can"t hurt. would 10w40 oil be alright?
Old Feb 14, 2010 | 12:21 PM
I'm not sure on that small of engine. We ran it in a 350 the leaked real bad, seemed to help.
