need motor building help
Old Jun 22, 2010 | 7:27 PM
zoomo's Avatar
Default need motor building help
Hey guys, I'm new here, and posting off my phone so 8 hope this is the right area. Please forgive typos az well lol. Alright heres what I have.85 or somewhere there, 350 four bolt main. It's knocking so I need to rebuild. Thesis where it gets complicated. I have a set of double hump heads that have been saved to 60 cc. So I'm going to have city motors rebuild it but I need some help on the technical things like how deep of a dish pisto. do I need for pump gas and if I need new pushrods, and also I'm at a loss for rockers. What size should I get? Anyways any help Is greatly appreciated. I'm sure yall will need moreinfo so just let me know. Thanks guys.
Old Jun 22, 2010 | 9:05 PM
72c10gunn's Avatar
What is the main use of the motor? Id say to run pump gas with those iron heads your compression ratio will have to be 9.5; 1 or lower, also what cam are you goin to be running? As for pistons if the CR is 10;1 with 64cc heads then it will be roughly 10.4;1 with the 60cc. About every 1cc equals .1 on your CR on small blocks.
Old Jun 22, 2010 | 9:14 PM
zoomo's Avatar
The motor is in my truck. It's just a daily driber. Right now Im running headers and an aluminum intake and I rebuilt the distributor with one of those advance kits that changes the springs. As far as cam I'm not sure exactly what I need in that aspect. I'd like something with like a 112 separation to give it a lope at idle. Yet like 230 on intake and exhaust so it still hws low end power. Giveeme some ideas though cause I could be making mywelf look like a fool. All I know about this is what I've read.
Old Jun 22, 2010 | 11:18 PM
72c10gunn's Avatar
A good cam would probably be edlebrocks performer for a daily driver or something similar to it. It builds power from idle to 5500. It probably wont give your truck a hard lope but you will be able to tell it has a cam.
sbcracing
Jul 17, 2013 10:20 PM
chevysam6
Camaro
Jul 14, 2011 1:28 AM
nicom
May 8, 2006 12:32 AM
