no power to AC fuse
Old Jun 21, 2018 | 1:39 PM
rarrambide's Avatar
Newly Registered
Default no power to AC fuse
2013 chevy express,AC fuse has no power,so compressor doesnt come on,jumpped pressure switch with no effect
Old Jun 24, 2018 | 9:42 AM
kevinkpk's Avatar
The fuse is the first thing in the circuit, so if you have no power to it, you have no power in that system at all.
Old Aug 2, 2021 | 5:13 PM
SoutnpaWill's Avatar
Default Fix?
I had the same problem did you ever fix it if you did throw me a text or email SouthpaWill1964@ gmail.com 530 340 3933
Old Apr 28, 2023 | 11:36 PM
treeman1's Avatar
Default no power to ac Fuse!
AC HELP
I have a 2007 chevy 3500 Silverado diesel work truck package, I have changed everything on ac, have had it working several times and now it won't come on unless we put a hot wire to the fuse, then compressor comes on and cools. But for some reason no power to the ac fuse. changed relay around still no power to ac fuse. New compressor, dryer, orifice, condenser, control panel, freon, etc. only thing not replaced was heater core. wiggled on all wires under hood, reset the fuse panel. I do have a glow plug for over 3 years that engine code shows. other than that, still trying to figure out, need help!
Drew001
Nov 1, 2022 8:44 AM
Goldmyne
Mar 30, 2021 6:29 PM
29tomt
Nov 12, 2015 8:59 PM
77chevyc10
May 10, 2014 7:34 PM
Equinox07
Dec 1, 2008 4:17 PM
