Not blowing heat!! heating issues
Good day, ladys and gentleman.
I drive a Tahoe 2010,LT. This baby is in North Caroline, it just star to chill out here. My AC work perfect, i try to set my heating, and is blowing cold on each of the vents on the vehicle, i don't see problems with actuators is just does not heat.
any suggestions please, will be welcome.
thanks
thanks
Tahoe - Have you checked your coolant level? If it's okay, then I would venture it's your heater core. Not familiar with your vehicle, but if you're lucky you can reach it under the dash. Since it's relatively new, I seriously doubt it'll be that easy.
how did you verify proper operation of the temp blend door and actuator? If it was mine, I would either watch the door counts with a scan tool or get my head under the dash to watch it move. I would do that before looking at the heater core.
do you get any heat when holding the rpms at 2500 after the vehicle has reached operating temp.
