Odd fuel econ issue
Old Jun 20, 2014 | 8:34 AM
Nalanthi's Avatar
Default Odd fuel econ issue
Good morning, all.
This may be a bit long-winded, but I've exhausted most of my options.
Original setup straight 6 (250) w/ a monojet carb that I rebuilt was giving me 5.6MPG, which completely sucks for an inline 250.
I swapped for a rebuilt 350 (specced, checked, and all stock minus a double-roller timing chain, flat pistons, and a high flow oil pump), rebuilt an early-model qjet which I also jetted 8% lean and was getting 4.3MPG.
Thinking it may be the qjet, possibly the fuel line since my econ sucked with two totally different engines, carbs, fuel pumps, etc., I swapped the qjet for an Edlebrock 1406 that was purchased new last fall and running on a different application flawlessly - also jetted 8% lean... and I'm getting 3.9MPG.
Engine holds good vacuum and compression readings when I tested. Initial timing it set at 10 degrees BTDC.
At the moment, I haven't cracked the pumpkin to check the gears, but my assumption is that they should be stock (around 3.73, 4.10 at the highest) considering the fact that this truck hasn't been lifted and was owned by a guy in his 70s. Either way, a near-stock gear ratio on 31s with a stock ride height with damn near everything under the hood having been rebuilt shouldn't be giving me a third of this truck's capabilities.
I'm at a loss - and would GREATLY appreciate any word on it (or question if I missed something).
Old Jun 20, 2014 | 11:30 AM
wildstrings's Avatar
What kind of fuel are you running
Old Jun 20, 2014 | 11:55 AM
Nalanthi's Avatar
86 (or 87).
The flat pistons I used in the engine build should put me at around 9 or 9.5:1 w/ stock heads.
I was under the impression that this wasn't too high of a compression for a low grade setup - am I wrong? Would i really make that much of a difference i.e. 1/3 of what I should expect from MPG?
Nalanthi
Jun 12, 2014 9:27 PM
CHEVYCRZY007
Jan 15, 2013 8:50 AM
fleachili
Jan 5, 2010 6:11 PM
ax7221
Apr 9, 2008 3:05 PM
n8tgc
Mar 9, 2008 3:44 PM
