Overheating
Overheating
I am new to the site and hoping that someone has either had the same problem or has a suggestion on what to do. I have a 96 S-10 Blazer and it has developed an overheating problem. This has started a couple of days ago. My dad who was in radiator business has been working with me on this. The radiator is a year old, new water pump, new thermostat, new clutch fan, upper radiator hose is fairly new. Flushed the system yesterday as well as put the new clutch fan on. It was okay coming back from my dad's and then this morning I took it to wash it and on the way home, it started overheating again. We haven't yet checked the timing, but I just don't know what else to do. Any ideas from anyone?? Thanks
Kevin
Kevin
RE: Overheating
"If the cooling system is low on water, the highest parts of the engine tend to overheat, causing the head to warp and the head gasket to blow out through the gaps left by the warping.
_________________
Car Parts Wholesale
_________________
Car Parts Wholesale
RE: Overheating
You mention replacing everything on the system but the one item with a sealing surface AND moving parts. Have you replaced the radiator cap? The gasket in the cap forms a set, or cracks, pressure in the system goes to zero and you're overheating. Depending on the area in which you live, use the minimum of antifreeze you need, because it's the water that's doing the cooling. Race cars which get pulled apart at the end of the race run 100% water, and I would too, if I could get away with it.
jessejames
15
November 16th, 2014 3:19 PM
jpp
June 5th, 2006 11:30 PM
CliffGriffin
January 28th, 2006 10:58 PM
