P0171, P0300 and Stabilitrak
Old May 16, 2019 | 4:56 PM
CParsons's Avatar
Question P0171, P0300 and Stabilitrak
I have a 2007 GMC Sierra SLE 5.3 L 4WD that has had a P0171 and P0300 plus Stabilitrak off and Transaction Control off thats comes on. When my P0171 and P0300 throws, the stabilitrak and transaction control always comes on. I do have every once and awhile service both stabilitrak and Transaction Control message. I have taken it to a few shops and they cant figure it out. I have replaced plugs and wires, bank 1 pre cat O2 sensor. I have had the MAF checked and they said it looks good. Every shop has checked for vacuum leaks with negative results. I have had my fuel pressure checked and they said it looks fine too. What else could it be and what am I missing. Thanks for the help.
Old May 16, 2019 | 5:02 PM
CParsons's Avatar
All of this happens when driving, when the truck is idling the truck runs just fine,
Old May 16, 2019 | 6:10 PM
CParsons's Avatar
Sorry for so many posts, I also had front end work, replaced the ball joints and u joints. Also had oil pressure send unit replaced and they took the intake off and replaced with new intake when they put everything back together.
Old Sep 30, 2020 | 11:38 PM
MiguelTapiaa's Avatar
Default Pr
[QUOTE=CParsons;428189]I have a 2007 GMC Sierra SLE 5.3 L 4WD that has had a P0171 and P0300 plus Stabilitrak off and Transaction Control off thats comes on. When my P0171 and P0300 throws, the stabilitrak and transaction control always comes on. I do have every once and awhile service both stabilitrak and Transaction Control message. I have taken it to a few shops and they cant figure it out. I have replaced plugs and wires, bank 1 pre cat O2 sensor. I have had the MAF checked and they said it looks good. Every shop has checked for vacuum leaks with negative results. I have had my fuel pressure checked and they said it looks fine too. What else could it be and what am I missing. Thanks for the help.[/QUOTE
Any Progress? having these exact symptoms!!
Old Jan 7, 2021 | 12:06 PM
CParsons's Avatar
MiguelTapiaa....There has been no progress with this issue. I can drive in 3rd all day long with no issues. When I put the truck in drive it will take a few minutes but the codes will throw. Have you had any progress with yours?
Old Jan 7, 2021 | 2:47 PM
Why did they take off the intake and replace it? You could possibly have some partially clogged injectors.
Old Jan 14, 2021 | 11:33 AM
CParsons's Avatar
The dealership said the book said to take off the intake to replace the oil pressure sending unit which i knew you can get around and leave it on. I told the dealership to leave it on. But they didn't listen, then when i got the truck back it started to throw the codes. I will see about getting the injectors looked at. Would it still be an issue with running in 3rd?
lmasbury08
May 16, 2024 7:28 AM
Joegorman07
2007 - 2013 (GMT900)
Jul 14, 2019 7:27 AM
SSI
Mar 2, 2018 12:14 PM
Chevy fan no more
May 30, 2017 3:44 PM
brandyesmith24
Nov 4, 2016 8:27 PM
