park assist
Old Oct 12, 2007 | 9:30 PM
ragin_cajuns's Avatar
Default park assist
when i started my truck [07 NBS Silverado, Z71 4x4, LTZ] this morning the the dash displayed a message saying that park assist was off. i didn't turn it off so i pressed the button to turn it back on - it blinked a few times but stayed off and would not come back on. i tried this a few times over the next 15-20 minutes but it stayed off. i got to work and noticed that it had turned back on by itself.
anyone know what's going on here?
thanks
Old Oct 13, 2007 | 11:42 PM
engine2's Avatar
Default RE: park assist
Strange. Did it happen only once or is this an ongoing issue?
Old Oct 16, 2007 | 8:08 AM
it has happened three times now including this morning.
Old Oct 16, 2007 | 8:17 AM
John86's Avatar
Some customers may comment that a 'Park Assist Off' message is appearing on the Driver Information center (DIC) at times.
There are several factors listed below that can cause this message to appear. A Tech 2 can be used to access the latest entry into the Park Assist Module history buffer to help determine a cause.
Inhibit Modes
Description
Manual Disable
Customer disabled via On/Off switch or Vehicle Menu.
Parking Brake
Parking brake engaged.
Attached Object
Any object detected by the system such as a trailer, trailer hitch receiver, bike rack, or lowered tailgate.
Reverse Overspeed
Vehicle driven in reverse gear over 8km/h (5mph).
Inhibit
Loss or invalid GMLan signal(s).
Sensor Disturbance
Ultrasonic noise from another vehicle with Park Assist, a jackhammer, or the compression of air brakes on a very large truck.
Sensor Ring Time
Sensors are dirty, covered with snow, ice or slush, or paint on sensor membrane is too thick after a repaint.
Engineering has received multiple inhibited Rear park Assist Modules through warranty parts return with attached object stored in the latest history buffer. If a vehicle has a trailer hitch installed into the trailer hitch receiver, it is possible for the rear park assist to be disabled. Once the trailer hitch is removed, the message should go away. Other possible causes may be dirty sensors. Keep the rear bumper free of mud, dirt, snow, ice and slush.
Old Oct 16, 2007 | 12:14 PM
i do have my trailer hitch receiver installed but didn't think that the sensors would pick that up and if it did pick it up it would be off all the time, not just 3 times in the last few weeks.
i'll take it off for a few days and see if it happens with it off. thanks
Old Oct 16, 2007 | 4:56 PM
John86's Avatar
being an 07 y don't u just take it to ur dealer for warranty work??
Old Oct 16, 2007 | 8:52 PM
because i'd rather not take the time to take it in if it is something as simple as the trailer hitch
Old Feb 6, 2008 | 8:50 AM
Smkyb's Avatar
I have noticed that my sensors are very sensitive to the cold weather. If there is the slightest bit of frost or road film from salt and sand the park assist will disable itself. I can wipe the sensors clean and it will allow me to turn the park assist back on, but not until I drive forward to a speed of about 20mph. It says in the manual the exact speed that needs to be driven before the sensors can be re-enabled. I think it is 20mph. Do you notice this on days it is frosty or your truck is particularly dirty. I can say that Ford does do a better job with their parking assist, but that is it everything sucks.
suzieq
Dec 9, 2023 11:40 PM
Rich2007Z71
Feb 6, 2020 1:59 AM
Bert36
Mar 14, 2009 8:15 PM
ragin_cajuns
Oct 12, 2007 8:20 AM
