Performance Sale: MSD Fuel Rails & Controllers -11% at CARiD
Old Mar 24, 2025 | 10:33 AM
carid's Avatar
Former Sponsor
Default Performance Sale: MSD Fuel Rails & Controllers -11% at CARiD
Whether you're looking to significantly increase your engine's power output, completely upgrade your fuel system, optimize shift control, or improve electrical efficiency, to get some dramatic changes in horsepower gains, MSD parts deliver the reliability and performance you can rely on. Today, we’re sharing our top-three picks from MSD: Fuel Rails, the Programmable Transmission Shift Controller, and the Stand-Alone Solid-State Relay, all manufactured to help you maximize your vehicle's potential. Give them a shot and experience improved fuel delivery, performance, and transmission control on your next drive.
Here’s a closer look at their key features and benefits.
The MSD Fuel Rails are designed for high-flow applications, making them an ideal choice for performance builds, turbocharged setups, and high-horsepower naturally aspirated engines. They are made of precision CNC-machined lightweight, high-strength aluminum covered with corrosion-resistant black anodized coating, to withstand high fuel pressures and harsh conditions. Each kit comes with high-pressure Leak-Free O-ring fittings ensuring a tight seal. They are designed for popular high-performance intake manifolds, making installation seamless for custom builds and aftermarket EFI setups while ensuring even fuel distribution to each injector.
MSD® 2720 - Fuel Rails
Specifications:
  • Emission Code 5;
  • Color Black;
Notes:
  • If using tall EV1/Bosch style injectors on LS7 or LT applications, there may be interference on low hood applications as on Corvette and similar;
  • 1999-2004 applications utilizing a factory supply and return fuel line will require the addition of a fuel pressure regulator when installing MSD fuel rails;
  • P/N 534-211 - Adapter kit, required when directly connecting Atomic fuel rails to GM factory fuel line quick-connect. Includes (1) 3/4-16 O-ring port plug and (1) -6 to GM quick connect adapter
  • SPECIAL TOOL REQUIRED: GM 3/8" Quick-Connect Release Tool to disconnect the factory fuel line (these are inexpensive and available at the local auto parts store);
  • Fuel rails are machined to accept large -8 (3/4 -16) O-ring fittings (sold separately) - Earl's P/N AT9850008ERL - 4 required;
For those running electronic automatic transmissions, the MSD Programmable Transmission Shift Controller is a top-pick, allowing you to monitor transmission temperatures, shift timing, and fault codes in real-time. This unit provides full control over shift points, firmness, and torque converter lock-up, allowing fine-tuned performance for street-racing applications. Any transmission configuration may be used, including up to a six-speed transmission. Programming the RPM and other options of the MSD Programmable Transmission Shift Controller can be done using the MSD Pro-Data+ Software on a Windows-based PC.
MSD® 75591 - Programmable Transmission Shift Controller
Features:
  • Ensures outstanding driving performance;
  • Made to provide fuel economy;
  • Guarantees outstanding durability;
  • Long lasting service life;
The MSD Stand-Alone Solid-State Relay can handle up to 30 Amps Continuous Load with an input voltage of 12 volts DC. It is a fully sealed construction, made from high-quality materials for ultimate durability and designed to provide instant, high-current switching. This Relay is the best choice when 12 volts are required, making it ideal for fuel pumps, electric fans, water/methanol injection, and even nitrous solenoids. Being compact, it can be easily mounted in tight spaces, making it ideal for custom wiring projects.
MSD® - Stand Alone Solid State Relay
Features:
  • Designed to deliver trouble-free, consistent performance;
  • Right for your vehicle and lifestyle;
  • Made from high-quality materials for ultimate durability;
  • Manufactured to meet or exceed strict quality requirements;
Upgrading to a high-quality aftermarket Fuel Rails and Transmission Shift Controllers can bring lots of benefits. If you're aiming to optimize your engine's performance and redefine the ignition system while improving starting and ensuring smooth idle, just choose from our immense selection of premium replacement electrical parts manufactured by MSD and experience the difference!
Old Mar 24, 2025 | 11:46 AM
carid's Avatar
Former Sponsor
March Performance Savings – Get 11% Off MSD Fuel Rails, Shift Controllers & Solid-State Relays!
Proper transmission tuning can make a huge difference in the performance and longevity of your vehicle, protecting it from wear and premature failure. Take your build to the next level with MSD Performance Parts! Fine-tune your transmission, optimize fuel delivery, improve acceleration, and refine shift points. No matter the task, MSD products are built to deliver the precision and reliability you need.
What’s on Sale?
  • MSD Fuel Rails – High-flow CNC-machined rails ensure even fuel distribution for maximum performance.
  • MSD Programmable Transmission Shift Controller – Fine-tune shift points, line pressure, and torque converter lock-up for total transmission control.
  • MSD Stand-Alone Solid-State Relay – High-current, solid-state switching for fuel pumps, fans, and performance accessories.
Purchase today and get 11% off these premium-quality MSD performance upgrades!
Offer valid through March 31st. Stock is limited, shop now and save!
To learn more about the manufacturer, check out our website: https://www.carid.com/msd/
Old Apr 17, 2025 | 3:05 AM
12ka442ka1's Avatar
That’s an awesome deal on the MSD Fuel Rails & Controllers—perfect time to upgrade performance! If you’re working on high-performance vehicles regularly, keeping your workspace clean is just as important as the parts you install. Oil spills, grime, and buildup can quickly take over a garage or workshop. That’s where a pressure washing trailer really comes in handy. It gives you the power and mobility to deep clean your driveway, garage floor, or even equipment with ease. Whether you’re detailing cars or just maintaining a clean working environment, it’s a practical investment that saves time and keeps everything looking sharp.
Old Aug 8, 2025 | 12:41 AM
comfortfurniture's Avatar
Creating the perfect space starts with choosing the right living room furniture that not only reflects your style but also provides comfort and functionality. Whether you're going for a modern, minimalist vibe or a cozy, classic look, picking quality pieces can make all the difference in how welcoming and practical your living area feels.
Theo Tash
Jul 19, 2023 3:33 PM
mountainmanjoe
May 9, 2023 10:09 PM
dariio1994
Apr 26, 2014 11:58 PM
endneu913
Apr 21, 2011 12:45 AM
