Please help
Old Aug 29, 2021 | 3:42 PM
Sk888888's Avatar
Default Please help
Need help with the meaning of this
this is my freeze frame data
Dtcfrzf. P0300
Fuelsys 1 cl
Fuelsts2 cl
load_pct 33.3
Etc 214
Shrtft1 -0.8
Longft1 16.4
Shrtft2 o.o
Longft2 16.4
Map 26.6
Rpm2598
Vss 81
maf 9.75
Tp 45.9
Old Aug 30, 2021 | 11:33 AM
freeze frame data is a snapshot of sensor readings when the fault occurred
dtc p0300 is a random misfire code
fuel system 1 cl = bank 1 fuel system running in closed loop
fs2 = bank2 running in closed loop
engine load % = 33%
etc= engine coolant temp 214*F
short term fuel trim bank 1= -0.8%
short term fuel trim bank 2 = 0.0%
long term fuel trim b1= 16.4%
long term fuel trim bank 2= 16.4%
Manifold absolute pressure sensor = 26.6
engine rpm = 2595
vehicle speed sensor= 81mph
mass air flow sensor= 9.75 grams/sec
throttle position sensor= 45.9
you have a misfire. you need to determine which cylinder is misfiring.
the fuel trim is lean....you may need to check for low fuel pressure. Can't post anything further as i don't know anything about the vehicle.
gixxerscott
May 20, 2021 10:15 AM
99_Silverado-2001_Z06
Feb 3, 2014 3:04 AM
jeffmike500
Sep 7, 2013 10:27 AM
73nova
Nova & Chevy II
Apr 5, 2011 9:21 PM
Z71freak35
Jan 15, 2008 7:14 PM
