please help no spark! 97 silverado c1500
Old Sep 26, 2015 | 11:39 PM
Myles Goodman's Avatar
Default please help no spark! 97 silverado c1500
I have a 1997 silverado c1500 5.7 2wd I have literally changed every part related to spark for this truck I ran a multimeter and a test light and a scan tool on it and still can't find an issue the only things I haven't tried changing yet are the wire harness and the pcm I have a 96 model as well that is somewhat of a donor truck since the transmission went out in it . The multimeter had a voltage of 10 when key was turned and would drop to 8 while cranking on the crank sensor the camshaft sensor the ignition control module and the ignition coil I tested to see if the ignition switch was bad as well and it checked out fine please help me get to the bottom of this! Thank you!!
stdhawaii60
Dec 24, 2010 11:14 AM
ckirchner
Dec 30, 2009 2:03 AM
lildude_3675
Dec 10, 2008 5:09 PM
