Power window
Old Mar 25, 2020 | 4:05 PM
LoweredS10's Avatar
Default Power window
I have a 2004 Xtreme blazer power window switch will not work in temprature over 80 plus degrees. If I disconnect main switch let sit for 10 minutes or so it operates fine. Replaced window motor about 10 months ago. Worked fine in the cooler months. First day over 85 degrees now acting up once again. Is there something called a module and if so could this be the cause and where would it be located.
Old Mar 25, 2020 | 10:57 PM
window motors usually have a thermal breaker. It probably needs changing.
MiragePilot
Jul 1, 2019 11:28 PM
noluck
Jun 28, 2016 8:45 PM
justin69
Feb 28, 2015 2:54 PM
MrChevy
Dec 27, 2009 9:15 AM
pcharles
K5 Blazer
Oct 18, 2009 9:03 PM
