Power window troubleshoot
Old Nov 13, 2017 | 1:48 PM
00montecarlo's Avatar
Default Power window troubleshoot
I recently purchased a 2000 Monte Carlo. The power windows don't work for either side with any switch. I pulled off the drivers side door panel and pulled the motor. I tested the voltage at the motor connector and I'm only getting 7 volts for down and 12 for up. Is that right? I pulled the motor and hooked it directly to the battery and it works fine in both directions. I plugged the motor back in, but it won't go in either direction. I have it disconnected from the regulator as well. What is going on here?
Old Nov 14, 2017 | 11:49 AM
Probably the drivers side switch is bad. If this switch is bad the other side won't work either.
