Problem with 96 2500 5-speed
Old Sep 17, 2007 | 12:48 PM
Silv83's Avatar
Default Problem with 96 2500 5-speed
I have a 96 K2500 5-speed with an idle problem. When you are driving and go to shift with the rpms above 3000 the engine stays at 3000 for8-10 seconds. Also according to my scan tool, the tach is off by at least a 1000 rpm and it has low idle air counts and slowly decreases. I've put an upper intake gasket, crankshaft sensor, PCV valve, and an idle air control solenoid from a dealer in. But the vehicleidles good one day but not the next.Any help with this would be greatly appreciated. Thanks.
Old Sep 17, 2007 | 5:01 PM
John86's Avatar
Default RE: Problem with 96 2500 5-speed
check ur throttle position sensor and ur map sensor.
Old Sep 17, 2007 | 6:56 PM
Silv83's Avatar
I have already reset theTPS and it has no drops in the wave form. The MAF sensor has been cleaned once but didn't help so I tried a new one and it made no difference.
captain177
Apr 8, 2021 1:34 AM
Kawasakii2003
Jan 3, 2013 5:06 PM
ericnottelin
Aug 6, 2012 9:09 PM
5:00 PM
Jan 7, 2012 11:38 AM
schwhack
May 28, 2008 6:44 PM
