Is this a problem with my starter or transmission?
Old Jul 28, 2019 | 5:26 PM
Wyatt Beltz's Avatar
Default Is this a problem with my starter or transmission, ignition, or something else?
Recently, my car has been taking a little bit longer to start and I don't know if it's my transmission or my starter. It cranks/“turns over” more than normal before the engine starts. I got the battery replaced so I don't think it would be that. The video below shows the "sound". I plan on going to a mechanic soon. I can only think of it being the starter, transmission, or ignition. Otherwise I dunno what it would be. Sorry if it isn't very loud.
File Type: mov
Old Jul 29, 2019 | 7:37 AM
Try spraying some starter fluid into the throttle body and see if it starts right away. If it does it is the check valve in the fuel pump assembly. The fix would be to change the fuel pump or add a check valve into the fuel line.
Old Jul 29, 2019 | 8:10 AM
+1 for fuel pump
cycle the key to run 4x before starting...this primes the fuel line and rail.
key to run...let fuel pump run for 2 seconds...key off...repeat 3x...then turn key to start.
