Programmer for '09 Silverado
Old Jul 14, 2009 | 12:17 AM
paradisepatiosAZ's Avatar
Default Programmer for '09 Silverado
I am thinking about picking up a programmer for my new '09 Slverado LTZ 4x4 with a 5.3. Open to suggestions and would like to hear from your experiences with different brands.
Thanks!
Steve
Old Jul 14, 2009 | 10:28 AM
MDTAHOE's Avatar
Professional Mechanic
From what I have read is a Black Bear Tune gives you the best bang for your buck. I have read that it is tailored to your driving and what you want to accomplish.
Old Jul 14, 2009 | 4:34 PM
shawnvw's Avatar
Banned
#09-06-04-026: Identifying Non-GM (Aftermarket) Engine and Transmission Calibrations for V8 Gas Engines - (May 18, 2009)
<TABLE border=0><TBODY><TR><TD vAlign=top width=100>Subject:</TD><TD vAlign=top>Identifying Non-GM (Aftermarket) Engine and Transmission Calibrations for V8 Gas Engines</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top width=100>Models:</TD><TD vAlign=top>2006-2009 GM Passenger Cars and Light Duty Trucks (Excluding Saab 9-7X)</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top width=100></TD><TD vAlign=top>2006-2009 HUMMER H2, H3</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top width=100></TD><TD vAlign=top>Equipped with V8 Gas Powered Engines Only</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top width=100></TD><TD vAlign=top></TD></TR></TBODY></TABLE>
<HR>General Motors is identifying an increasing number of engine, transmission and catalytic converter part failures that are the result of non-GM (aftermarket) engine and transmission control calibrations being used.
When alteration to the GM-released engine or transmission control calibrations occurs, it subjects powertrain and driveline components (engine , transmission, transfer case, driveshaft and rear axle) to stresses that were not tested by General Motors. It is because of these unknown stresses, and the potential to alter reliability, durability and emissions performance, that GM has adopted a policy to cancel any remaining warranty coverage to the powertrain and driveline components whenever the presence of a non-GM (aftermarket) calibration is confirmed - even if the non-GM control module calibration is subsequently removed.
Warranty coverage is based on the equipment and calibrations that were released on the vehicle at time of sale, or subsequently updated by GM. That’s because GM testing and validation matches the calibration to a host of criteria that is essential to assure reliability, durability and emissions performance over the life of the warranty coverage and beyond. Stresses resulting from calibrations different than those tested and released by GM can damage or weaken components, leading to poor performance and or shortened life.
Additionally, non-GM (aftermarket) issued engine control modifications often do not meet the same emissions performance standards as GM issued calibrations. Depending on state statutes, individuals who install engine control module calibrations that put the vehicle outside the parameters of emissions certification standards may be subject to fines and/or penalties.
This bulletin outlines a procedure to identify the presence of non-GM (aftermarket) calibrations. GM recommends performing this check whenever a hard part failure is seen on internal engine or transmission components, or before an engine assembly or transmission assembly is being replaced under warranty. It is also recommended that the engine calibration verification procedure be performed whenever diagnostics indicate that catalytic converter replacement is indicated.
In May 2009, the PQC will begin piloting a process to confirm the ECM/PCM calibration is GM issued. Beginning on May 18, 2009, the PQC will require a picture of the engine calibration verification screen, as outlined in this bulletin, before authorizing any V8 gas powered engine replacement.
If a non-GM calibration is found and verification has taken place through GM, the remaining powertrain and driveline warranty will be cancelled and notated in GMVIS and the dealership will be notified.
  1. <LI type=1>Plug in the Tech 2®. <LI type=1>Go to diagnostics and build the vehicle. <LI type=1>Select "Powertrain". <LI type=1>Select "Engine". <LI type=1>*Select "Engine Control Module" or "PCM". <LI type=1>*Select "Module ID Information" or "I/M Information System" if module ID information selection is not available.
  2. *If "I/M information System" was selected, it may be necessary to select "Vehicle Information" in order to display the calibration information.
  1. <LI type=1>Take a CLEAR digital picture of the Tech 2® screen showing the engine calibration verification information as shown above. <LI type=1>E-mail the snapshot picture to **REMOVED** In the subject line of the email include the phrase "V8 Cal" as well as the complete VIN and Dealer BAC. In the body of the e-mail, inlcude the VIN, mileage, R.O. number and BAC. <LI type=1>Allow two hours for the PQC to verify the calibrations and set up the case details.
  2. You may call the PQC two hours after submitting the e-mail for authorization to replace the assembly. This will provide them time to receive, review and set up a case on the request. Please be prepared to provide all the usual documentation that is normally required when requesting an assembly authorization from the PQC.
Old Jul 15, 2009 | 12:39 AM
Shawn,
Thank you for your feedback. So to enhance performance would you stick with a catback exhaust and a cold air intake and go no further to stay within the limits of warranty? I am very respectful of my equipment and am looking only for an extra nudge when towing and when doing so always run premium... Still feel it is a risk of using the tuner in the rare occasion?
Thanks for the great info
Old Jul 15, 2009 | 11:22 AM
MDTAHOE's Avatar
The Black bear tune can be set up so that it can be removed, the dealer would never know it was there. Almost everything you do to your truck can void the warranty. I have only read about this tune on forums and have no experience with it.
Old Jul 15, 2009 | 1:02 PM
shawnvw's Avatar
Banned
As MDTAHOE said....if you are going to mess with the software, make sure you can put the stock program back into the ECM before bringing it to the dealer. I have no experiance at al with aftermarket programmers so I can't give you any info on whats good or not
Dealers will have a hard time voiding warranty if you just do a cat back system or cold air intake, so if you are worried about it, stick with with the hardware untill the warranty is up, then play some more after.
Old Jul 16, 2009 | 10:53 AM
therewolf's Avatar
I just want to state here that my K&N(one of the better brands) CAI cost me less than, and enhances my performance much better than my programmer. A decent CAI should give you the extra power when you want it. I know it did for me.
I have to wholeheartedly agree with MDTahoe and ShawnVW to stick to your warranty, and wait till it expires to take any extreme measures for modifications.
mbazile
Aug 2, 2012 10:04 PM
mx519
Jun 21, 2012 10:28 PM
JustinSilverado
Jul 18, 2011 9:01 PM
b_sikes07@msn.com
Dec 26, 2010 12:50 AM
Tatonka
Feb 22, 2008 3:00 PM
