programming keyless remote for 2002 cavalier
Old Mar 15, 2008 | 8:14 PM
gregk3344's Avatar
Default programming keyless remote for 2002 cavalier
I just purchased a 2002 cavalier ls for my daughter and it did not come with the keyless entry. I purchased one at GM and got home with it and realized it did not come with any directions as how to program it to the car. I was told by chrey dealer that according to my vin that I had it on the car. Any info would be most appreciated. Thanks, greg
Old Mar 16, 2008 | 11:22 AM
dewey's Avatar
Default RE: programming keyless remote for 2002 cavalier
Do you have an owners manual? It should give you some info on manual resynchronization for the remote.
Stand close to the vehicle, hold the lock and unlock bottons at the same time, hold for 10 seconds. During this time the doors should lock and unlock once, that confirms the resynchronization. If you don't get any action from the doors, talk to the dealer. The remote does have a battery in it, correct?
Old Mar 16, 2008 | 12:09 PM
ampchevy88's Avatar
Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold down until instructed to release.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
11. Repeat the previous step for each additional transmitter (including any existing transmitters).
Old Mar 18, 2008 | 10:44 AM
ehhget's Avatar
Good luck man it took me ten tries to get it right on my truck!!!!
Old Mar 18, 2008 | 10:54 AM
TransAm Man's Avatar
I had a jetta with the same problem and I never got it to work.
chachas
HHR
Oct 31, 2009 1:37 PM
SeventyZ28
Dec 1, 2008 8:44 AM
allenc
May 25, 2007 5:54 AM
davidchevy
Dec 16, 2006 6:15 PM
silverzz28
Nov 16, 2006 9:48 PM
