Pumped 350
Pumped 350
Hello,
I am not a chevy guy so I need some input and advice.
I have a 350 bored .030 over. It has ported and polished 2.02 fuelly heads with roller rockers and a roller cam. The lifters look good with no wear. It has an aluminum intake with a double pumper. It is four bolt main with a miloden pan. It is an early style block with only two soft plugs on each side. How much do you think I could sell it for? Someone took care when rebuilding this engine and nothing should need replacement except for maybe rings and bearings and they may not even need replacement. Thanks in advance.
Jake
Jake
5.0stang
June 16th, 2022 7:46 AM
computerdude14
January 8th, 2013 3:33 PM
shawnmid
August 4th, 2010 1:19 AM
shawnmid
May 22nd, 2009 7:29 AM
