replacing the antifreeze, messy but effective
Old Apr 27, 2008 | 7:26 PM
stickershock's Avatar
Default replacing the antifreeze, messy but effective
Just finished replacing my antifreeze today on the 04 Impala 3.8 K engine. I offer this post to those of you handy enough to do this and want to save a fair amount ofmoney at a shop.
The problem with changing the antifreeze yourself is that it can be messy. Also, finding the radiator petcock to drain it is hard to get on my car and harder to turnif you are on your back under the car. So I gave up trying to drain the radiator. The system is a 3 gallon one so have a 5 gallon bucket ready to have a hose empty out the backflush.
I used a Prestone backflush kit which is a ripoff, sort of. You only need the two hose clamps they give you and one tee of three and a backflow coupler. The splash deflector tube was a joke and didn't workwith my radiator. I installed the tee on the upperheater hose near the firewall. The hose was very tough and a knive did not work. I used some very sharp kitchen scissors. (by the way, the instructions on the Prestone kit were based on rear wheel drive cars obviously, because thepictures show a early model engine, ie notfront wheel drive like today.Prestone really ought to revise its graphics!).
I found a hose that would fit snug into the radiator cap opening and letthe other end feed into the bucket. Putting agarden hose to the tee in the heater hose, I turned on the water and backflushed the engine when itgot hot enough to open the thermostat. Two people arebest to help turn theengine on or off as needed. So far, this was the "easy" part.
Now to put in the new antifreeze. You take off the garden hose at this point and screw the cap back on the tee at the heater hose. I used the undiluted antifreeze, not the 50/50 premixed you can buy today. But since my radiator was full of water now and could not be drained through the petcock easily, I took a shot at just running the engine a short while to drain the radiator that way. I was prepared to pour in6 quarts of antifreeze into the radiator, but found I had to use almost 8 quarts of pure antifreeze toget the boilover protection to 268 degrees F. So I just startedand stopped the engine a few times with the screw cap on the tee lose, but not completely removed from the tee. Awide plastic cup under the tee caught the trickle of water coming from it when the engine was running. Now I had room to add more antifreeze to the radiator. After letting the engine cool down a bit, I rechecked the fluid level and the level of boilover protection several times before I could stopaddingantifreeze.
Then I took the car for a ride and stopping afew times tocheck for leakes, which there weren't.Finally, I took it on the highway for a while. Checking theheatguage, theengine temp never got over 200 degreesF during the entire drive or even whenat idle at a stopsign (200degrees is the halfway mark between Hot and Cold onmy guage).
This whole proceedure could have been easier if I could have drained the radiator at the petcock, but instead it was messy and a bitawkward, but on the whole it saved me about$40-60 after buying the antifreeze and flush kit.
After all of this, maybe you would rather just pay to have the antifreeze changed at a shop?
f16_fixr
10
Aug 26, 2015 9:15 PM
texastcowboy
Jun 30, 2008 5:20 PM
kdeinv
Dec 31, 2006 10:09 PM
