Replacing ignitin switch - 1999 Suburban
Old Jan 6, 2008 | 7:32 AM
jeffwest5599's Avatar
Default Replacing ignitin switch - 1999 Suburban
Anyone ever replaced the ignition switch in a suburban? How hard is it to replace it? Any tips would be great. Mine is a 1999 model.
Jeff
Old Aug 14, 2010 | 10:46 AM
fatherRON's Avatar
Default Hope This Helps
Remove the steering column shrouds. Once the column is exposed, on the top of where the ignition lock is mounted there is a hole. Insert the key into the lock. Rotate the lock to the ON/Start position. Insert an allen wrench into the hole and pull on the lock cylinder.
jzkemler1
Jun 21, 2013 9:54 PM
realbadchevy
Aug 5, 2011 4:15 PM
eknight11
Feb 15, 2010 8:23 PM
jeffwest5599
Jan 6, 2008 7:33 AM
