rough idling
Old Jul 26, 2025 | 1:26 AM
edwadway's Avatar
Default rough idling
Hello I’m from the South , I have an 1992 GMT400 / C1500 4.3 Liter V6
Automatic, I am having rough idle, I have replaced spark plugs and wires, ignition coil, rotor, distributor cap, the MAP , Throttle Position Sensor, EGR valve, EGR Solenoid, ETC Coolant Temperature sensor on intake manifold, IAC on Throttle body, still having mirrors shake at stop sign, run smooth when accelerating, but sitting at a light idling, runs bad, please help? Also changed the O2 Sensor, also replace Fuel pressure regulator, bought 2 Fuel injectors, but had one installed backwards, and need to correct it, not sure what else to do. Bought a Vapor vent valve, but don’t know where it goes.
Old Jul 27, 2025 | 7:47 AM
Robby17's Avatar
Check for vacuum leaksspray carb cleaner around hoses and intake while running, listen for RPM changes. Fix that backwards injector ASAP. Also, clean the throttle body and test fuel pressure. If still rough, suspect a weak fuel pump or clogged cat. Vapor vent valve goes near the fuel tank follow the charcoal canister lines.
Old Jul 27, 2025 | 11:47 AM
edwadway's Avatar
Ok I will do that today, thanks
Old Jul 27, 2025 | 4:43 PM
LunaTek369's Avatar
With having replaced all of those parts, Im guessing that you disconnected your battery at some point. In which case, I suggest you do an idle relearn. You'd be surprised at the difference it can make sometimes. Especially on older cars such as the one in question.
Old Jul 27, 2025 | 5:52 PM
edwadway's Avatar
Yes I did thanks so much
charrisps6
Jun 20, 2019 10:30 PM
mikeg
Jul 26, 2016 3:08 PM
rmoore45
Feb 13, 2015 1:35 PM
dnorthover
Jul 13, 2010 11:14 PM
Grr Rawr
Jan 14, 2008 10:09 AM
