security toggle help
i want to install a toggle switch that i can hide that will allow me to disconnect or connect my ignition, that way if i was leaving my truck somewhere where i thought there was a possibility that it could be stolen, and i could simple hit the switch on my hiden toggle switch that would disable the ignition, does anyone know how you would wire that?
through the positive wire off the battery, to make it simple, just wire it in using solder and heat shrink and the same guage wire already in the truck and put the switch under the hood (when asking for the switch tell him you want a night switch from a piece of machinery, they are the best for this) if u want to make things complicated wire the switch into the cab
98Z71RI
Nov 2, 2013 7:37 PM
