shift pattern
Old Apr 10, 2011 | 1:58 PM
verr1908's Avatar
Default shift pattern
Hi could some body tell me the shift pattern for a 700 r4 as i need to make a shifter so need to know is it P N R D D! L ??? simple but i do need to know
Old Apr 11, 2011 | 6:47 PM
RacerX's Avatar
P R N O D 2 L. Depends on what you have but that is it generally.
Old Apr 13, 2011 | 1:17 AM
verr1908's Avatar
Thanks so will only need the shifter to move in to P N R O as it is in a hotrod
placing the shifter in postion O will cover all froward gears
Old Apr 13, 2011 | 7:36 AM
RacerX's Avatar
if it a hot rod then you should want to skip Overdrive and go straight to Drive. But in a drag situation like a highway on ramp you might want to downshift to 2nd and keep it there to build speed, then upshift to 3rd.
Usirish
Jul 18, 2019 4:00 PM
8rings
Jan 5, 2010 8:42 PM
jpows
Mar 11, 2007 3:45 AM
WGVette
Sep 27, 2006 2:48 PM
