Silverado Brake lights out?? huh?
Old Apr 14, 2011 | 10:12 PM
bucks4tony's Avatar
Default Silverado Brake lights out?? huh?
2005 Silverado 1/2 ton 4wd 5.3... Brake lights on the bed are not working.
3rd brake light on the cab works, Left and right turn signals work, Hazards work, running lights work, and trailer brake lights work. Brake fuse is fine, in fact I checked alot of other random fuses. Bulbs are fine as well. Any one have any ideas?
Old Apr 15, 2011 | 11:02 AM
Official GM Rep
bucks4tony, are you looking to fix the vehicle yourself or are you willing to see if the dealership could diagnose the vehicle? You could simply use the diagnosis as a starting to fix it yourself with a better knowledge of what to look into. Or you could have the vehicle fixed by them as well. I hope that helps you and I hope to hear back from you soon.
Jeff Morris, Chevrolet Customer Service
Old Apr 15, 2011 | 11:43 AM
EinST's Avatar
Welcome to the forum. By "Brake fuse," do you mean the 15A VEH STOP fuse in the left I/P fuse block? Have you actually checked the voltage at both test holes on that fuse with the brake pedal depressed?
Old Jun 16, 2013 | 3:03 PM
nattsretsoc's Avatar
Please advise which fuse to check?
Old Jun 16, 2013 | 3:04 PM
brake light is working on top of cab but the tail brake light do not come on. Anyone trouble shoot this before?
shanoahgood
Mar 20, 2013 10:45 PM
pmtwiss
Oct 8, 2011 10:56 PM
skdevore
Aug 26, 2009 10:18 PM
